(3) Codes: p1495, p1294 and p0443, what exactly is the problem?
Old Jan 19, 2011 | 01:52 PM
vikingdiesel's Avatar
vikingdiesel
Default (3) Codes: p1495, p1294 and p0443, what exactly is the problem?
I know the p0443 is something to do with emmissions, but what about the other two, I do get a little weird idle and misfire when im at the red light but it goes away and has plenty of power as soon as I give it gas?? The idle will fluctuate from 700 to 800 to 900 back to 800 rpm.... etc
Old Jan 19, 2011 | 02:55 PM
P0443 Evap Purge Solenoid Circ
P1294 Target Idle Not Reached
P1495 Leak Detection Pump Solenoid Circ
You have a vacuum leak in the vapor recovery system. Check ALL the lines running from the cannister, which on yours, should be on the passenger side, up under the bed, mounted right to the frame, to wherever they go. Also check and see if you cannister has puked its carbon into the lines.
Old Jan 19, 2011 | 03:45 PM
vikingdiesel
Any pics of this canister so I know what to look for?, so all 3 of those codes are related to this canister vacuum leak
Old Jan 19, 2011 | 03:50 PM
No pics, but, download the 01 service manual from the faq section here. It has some pretty good diagrams and such.
Yep, they are all related.
Old Jan 19, 2011 | 03:55 PM
vikingdiesel
Old Jan 19, 2011 | 04:06 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Old Jan 19, 2011 | 05:49 PM
95RAM360's Avatar
95RAM360
the charcoal canister should have the shape of a can of pepsi (or coke if preferred) and its a bit bigger then a can
