Hub Nut Size?
#41
Sheriff, what did you shove in the stub shaft to keep it from moving? I broke 3 solid steel chizels trying to get mine off a few months ago. I just said "**** it" and still have a bad U-joint in there. I couldnt get the damn thing off for anything.
I have some Aero-Kroil at the apartments that I'm gonna rob to get this ****ker off. I couldnt even budge it with an impact wrench!
#42
#43
You have stock rims, so you can remove the wheel and take the center cap out. Put the wheel back on and give it a go.
#44
I too remember reading about left hand threads in the Haynes manual, but I tried it both ways and that bastard wouldnt budge.
#45
#50
on
I think it's called a crows foot. It's a pry bar that tapers down to a point on the end that is is the heat vanes on the rotor. It was the rotor, not the stub shaft. That's why the caliper mounting bracket is still on in the picture.
To see if you have reverse threads you just have to look at them. If they slant away from you toward the right side of the stub shaft (threads on the right will be further away than the left side) when you're looking at the end then they're right hand threads. If they slant further away toward the left then they're reverse threads.
