REALLY bad oil consumption
Old Jan 20, 2011 | 04:49 PM
98ram4x4slt's Avatar
98ram4x4slt
Default REALLY bad oil consumption
Ok. i got a 98 ram slt 5.2 with 130k. I am burning yes burning not leaking not plenum not pcv. 1 QUART per 300 miles maybe more. I occasionly have and erratic idle. And occasionly when i accelorate from a stop at about 40% throttle the truck bogs down like its starving for gas. until i let off and lay on it. My o2 sensor throws a heater circut when its below freezing outside. i have a slight exaughst leak. maybe the air is messing with the ratio for the sensor idk. Sensor is fairly new. not valves or ring got 170pds in 7 of 8 holes and one with 150. maybe bad fuel injector? all the plugs are carboned up and so is the o2. but not oily. Please any help would be great.
Old Jan 20, 2011 | 04:51 PM
dodgeram07's Avatar
dodgeram07
our a 100% sure plenum gasket
did u try a wet conpresstion
are u running a mopar pvc
Old Jan 20, 2011 | 04:55 PM
If you are indeed burning the oil, need to figger out how it is getting in there. What led you to the conclusions of what it is not? Plenum and PCV can account for a LOT of oil consumption.......
Aside from those, it would be either rings, or valve guides. Neither of which is cheap to fix.
Old Jan 20, 2011 | 05:27 PM
99dodge318's Avatar
99dodge318
or a rear main seal
Old Jan 21, 2011 | 02:34 AM
98ram4x4slt
replaced rear main when i did the oil pan. i just replaced plenum and its clean. not a mopar pcv but about to be hoping for the best. and everyone i talked said it couldnt be that with such good compression....unless i was misled
Old Jan 21, 2011 | 12:28 PM
J415's Avatar
J415
Any blue smoke coming out of the tail pipe?
Old Jan 21, 2011 | 12:31 PM
My truck went thru three quarts a week, being driven less than 200 miles.... and I rarely saw smoke out the tailpipe. Fixing the plenum reduced consumption, but, it wasn't until I got a PCV valve from the dealer that it dropped to almost nothing. Aftermarket PCV valves are not consistent in their flow rates, and some of them are just WAY wrong.
Replace the PCV valve with a unit from the dealer.
Old Jan 21, 2011 | 12:43 PM
Road Hammer's Avatar
Road Hammer
If you are "burning" a quart every 300 miles, I'll bet the fire dept follows you everywhere! It must be smokin out the tailpipe like crazy! They'll love ya in the summer, a real "mosquito killer"! LOL
I had an old bush beater 4X4 that burned about a quart every 250 miles and lordy, lordy, you didn't want to get stuck with it, cause that sum bit*h would put you down with the smoke and fumes comin outta the tailpipes! LOL I think the only reason it never fouled a sparkplug was because it spent most of it's runnin time WFO !!! LOL
Old Jan 21, 2011 | 01:24 PM
98ram4x4slt
NO SMOKE at all dealership is having the pcv shipped
