Need help with a V10
Old Jan 25, 2011 | 10:19 PM
Justin3's Avatar
Justin3
Hasn't been any cats since 2001...
Old Jan 26, 2011 | 07:45 PM
VEETEN's Avatar
VEETEN
For the coil packs, It's in the Haynes manual I could type it but it's hard to explain the pin outs.
Basicly you check from the pins to pins and then point to point.....
See like I said it's hard to explain...LOL Do you have a haynes?
Old Jan 26, 2011 | 08:35 PM
Justin3's Avatar
Justin3
I do not have the Haynes manual but I can pull up the procedure at school. Don't know why I didn't think of that before.
Old Jan 26, 2011 | 08:51 PM
VEETEN's Avatar
VEETEN
to check primary side of coil pack put a meter set to Ohms, between pin B+(center pin) and coil 5,10 (left pin) you should get a resistance between 0.53 to 0.65 ohms.
repeat for other coils using center pin(B+) and right pin (coils 9,8)
to check secondary side you would put one lead on each side of the towers that share a coil. That is check the points on the left side 0ne at 12 oclock and the other at 6 oclock then check the 2 on the right at 12 and 6 oclock, resistance should be between 10,900 and 14,700 ohms.
