issues with oil preasure since 1.7 roller rockers
Old Jan 21, 2011 | 12:13 AM
  #21
lastrights's Avatar
lastrights
if you dont mind me asking how much was the job to paint that truck ?
Old Jan 21, 2011 | 01:00 AM
  #22
RamSport97's Avatar
RamSport97
Yeah it seems like these guys have all the bases covered. Sorry but I want some pics of that truck. Looks great!
Old Jan 21, 2011 | 08:47 AM
  #23
dodgeman2289's Avatar
dodgeman2289
they are harland sharp 1.7 non adjustable from summitracing. and the paint job was 3000. i have all the pics i took in my garage check them out!
Old Jan 21, 2011 | 09:45 AM
  #24
TS6034's Avatar
TS6034
Hey, nice looking truck! Don't sweat about now soaking the rockers, thats for lifters. As you said, you only need to lube em up with oil. The rockers have nothing at all to do with oil pressure as they are at the end of the line sort of speak.
Not sure if I missed something, but are you reading the dash guage or did you install a mechanical one?
Old Jan 21, 2011 | 10:16 AM
  #25
dodgeman2289
yes im reading the dash guage.. so how long does it take to break them in?
Old Jan 21, 2011 | 10:30 AM
  #26
dodgeman2289
even my 0-60 is about the same maybe a bit slower.. these things are sapposed to add another 10 hp to wheels. i got the dyno numbers from a website that sells them and dyno from a 5.9 like mine
Old Jan 21, 2011 | 10:34 AM
  #27
zman17's Avatar
zman17
Retired Moderator - RIP
Maybe related, maybe not, but I see no mention anywhere about any work done to the intake,like lower gasket/plenum.
Old Jan 22, 2011 | 10:08 AM
  #28
dodgeman2289
yeah no work dont the the lower intake or plenum gasket. as far as im concerned its all good
Old Jan 22, 2011 | 10:12 PM
  #29
TS6034's Avatar
TS6034
More than likely, you won't notice a 10hp gain. Plus, you need to do more than just a higher ratio rocker. You're on the right track though. Do you have plans on other upgrades too? Like an intake, cam, injectors, etc?
Old Jan 23, 2011 | 01:29 PM
  #30
redheadhunter21's Avatar
redheadhunter21
You said you have done seafoam lately, have you checked your plugs one side effect of seafoam is the possibility of fouling plugs, that would definantly slow the truck back down, and with a reg cab you should be able to smoke them tires easily, you might want to check plenum also as previously stated
