lift spindles
Old Jan 21, 2011 | 03:32 AM
Rpare92's Avatar
Rpare92
Default lift spindles
hey guys im thinkin about liftin my 99 2wd with 3 inch spindles and a 3inch body lift. Ive heard you have to get new wheels with the spindles but ive seen people with spindles and stock rims is it a must have or just something you should get? im just lookin to run a 285/75/16 tire and id like to have the stock rim. also would that amount of lift put me at the stock 4x4 height?
Old Jan 21, 2011 | 08:44 AM
dipsherry's Avatar
dipsherry
you HAVE to use 17 inch wheels...no way around it... i have 2.5 inch springs on mine and i clear 315-75-16s...only rub at full lock
Old Jan 21, 2011 | 09:37 AM
shorty24v's Avatar
shorty24v
[QUOTE=dipsherry;2389238]you HAVE to use 17 inch wheels...no way around it... i have 2.5 inch springs on mine and i clear 315-75-16s...only rub at full lock
What size tire you running? - you say you have to the 17" rims, but your running 315/75 16?
Old Jan 21, 2011 | 09:58 AM
dipsherry's Avatar
dipsherry
[QUOTE=hiusmell;2389275]
sorry i might of worded it confusing but i ment if you run lift spindles you need 17 inch wheels...i have no spindles only lift springs
Old Jan 21, 2011 | 10:03 AM
dipsherry's Avatar
dipsherry
Old Jan 21, 2011 | 10:58 AM
dodgeram07's Avatar
dodgeram07
yes you will need 17in+ size rims to clear the upper ball joint
ok but you may be in luck because in about 99 the 2wd spindles changed to a one piece wheel bearing, and they dont have a spindle nut stickin out 2.5in's
so that means of have more rims that you can use, like 17in rims off 3rd gens or dodge off road edt rims,...ect
so it may just cost other 100 buck + -, to pick up a used set of rims
alot of spindle's say use OEM off set,
Old Jan 21, 2011 | 11:21 AM
terribleswiss's Avatar
terribleswiss
im running the fabtech lift spindles and upper arms with 16 inch wheels, the backspacing on the wheel has to be different from stock to clear everything
Old Jan 21, 2011 | 01:22 PM
dodgeram07's Avatar
dodgeram07
you could run 16in wheels with a diff backspacing but alot of the spindles i have seem say to run a OEM back spacing so they dont break
but the is a truck on here with lift spindles,,, Doetsch Tech like 3.5in and he runing like a 16in soft 8 wheels and not problems yet,,, i just wouldnt want to risk it
you are going to need new rims both ways
Old Jan 21, 2011 | 02:10 PM
redheadhunter21's Avatar
redheadhunter21
It depends on the brand of the spindles, most of them will only work with 17in rims, but when I was looking a couple places said they will work with factory rims, best bet is to start calling around, ebay had a couple for sale
Old Jan 21, 2011 | 03:34 PM
TheBigRedOne's Avatar
TheBigRedOne
WTF? No, get out now.
This truck that I bought rides on modified Doetsch 3.5 inch spindles. The modification made to them has no bearing on wheel size or dimensions. I clear a 33x12.5, 16" 5x5.5 wheel with 4.5 in backspacing with very minor rub at full lock.
You don't have to have 17 inch wheels.
