wiper fuse keeps blowing
Old Jan 21, 2011 | 01:17 PM
dipsherry's Avatar
dipsherry
Default wiper fuse keeps blowing
ok today i started my truck let it run for about half hour to melt snow. 7 inches of it... then i went out and scrapped windows and went to take off... well i guess the -4 degrees froze my wipers to windows. so i made it to work and no wipers i looked and fuse was blown... now my wiper fuse keeps blowing i put a 35 amp in there and it pops as soon as you hit the wipers? what to look at
Old Jan 21, 2011 | 03:44 PM
If the arms are free of the windshield.... start looking for a short. Not sure how much difference there is between the 94's, and the 01's...... probably quite a bit...... not sure the manual online here is gonna help much.
Old Jan 21, 2011 | 05:14 PM
dodgeboy1979's Avatar
dodgeboy1979
i'm pretty sure the wiper fuse is only 25 amp. Always use the correct fuse or you could have a wire fire. I would start at the wiper motor, put a vlot meter on the terminals and have someone turn the wipers on and see what you are getting for amps. I believe the wipers run through the multifuntion switch in your steering colum.
Old Jan 21, 2011 | 06:10 PM
I would be more tempted to disconnect the wiper motor, replace the fuse, and then turn on the wipers, and see if the fuse still blows.
Old Jan 21, 2011 | 07:16 PM
ontimeanthony's Avatar
ontimeanthony
For what it's worth, had the same exact problem a month ago. The oem wiper motor itself had a short in it. Replaced it, everything is fine.
Old Jan 21, 2011 | 11:39 PM
dipsherry's Avatar
dipsherry
i like your way of thinking. i never had any problems with it up until today is there a chance i melted a wire or something in the motor causing it to short itself out now. cause it was trying to run the whole time i was driving to work?
Old Jan 21, 2011 | 11:44 PM
dipsherry's Avatar
dipsherry
ok just ran outside took a wire directly from battery and spliced it in motor runs fine?
