Misfires!
Old Jan 26, 2011 | 12:23 PM
  #31
zman17's Avatar
zman17
Retired Moderator - RIP
Your friend is wrong!
Old Jan 26, 2011 | 12:28 PM
  #32
eggie329's Avatar
eggie329
Yeah I'm not convinced on the timing yet! It would constantly mis if the timing were off right?
  #33
Not necessarily. MAP sensor reads manifold vacuum, it doesn't care that the readings just don't make any sense. So long as the PCM is getting a reading that is within the acceptable range of the sensor, it considers it Valid. Very seldom will a vacuum leak set a map code. Usually, what you find are the results of the leak setting a code, or causing a problem.
Old Jan 26, 2011 | 12:38 PM
  #34
eggie329's Avatar
eggie329
What do you recommend for finding vacuum leaks besides risking my eyebrows with a can of starting fluid the old fashioned way!?
Old Jan 26, 2011 | 12:58 PM
  #35
Gary-L's Avatar
Gary-L
Veteran: Navy
Idle the engine and spray with WD-40. The idle will kick up when the vacuum leak area sucks in the WD-40.
Old Jan 26, 2011 | 01:00 PM
  #36
But that won't find a blown plenum gasket.
Old Jan 26, 2011 | 01:07 PM
  #37
zman17's Avatar
zman17
Remove the TB and look in the intake with a mirror and light.
