As long as the truck stays on the road you should be good with the 14x3 and the stock tube is not smooth causing it to be restrictive to air, plus stock filter is pretty restrictive, 14x3 or CAI will be better than stock, and a quality element will help with throttle response and the motors ability to breathe...allowing the ability for better mpg
I'm running the K&N fipk cold air intake, and mopar valve covers . Get this i spent 12 bucks on the grommett set and they didn't fit at all. had to go to O'riellys to buy some grommets and rig em.
