SCT tuner
Old Jan 29, 2011 | 10:11 AM
EndIsNear's Avatar
EndIsNear
Its a programmer, so you plug in a cord from your trucks port under the dash to the programmer. The programmer displays a screen that, after a few turns of the ignition key, will give you the option of Diagnostics, or your choice of three tunes (custom or preloaded). After selecting, you will be asked a few simple questions, and then the selected tune will program into your computer. Then, viola! Your truck is tuned.
Old Jan 29, 2011 | 10:12 AM
EndIsNear's Avatar
EndIsNear
You then remove it...
Old Jan 29, 2011 | 10:26 AM
BIGBIRD85's Avatar
BIGBIRD85
LMAO!!!!!!!!!!! ok then!!
Old Jan 29, 2011 | 05:11 PM
lastrights's Avatar
lastrights
then you jerk off on your steering wheel !
Old Jan 31, 2011 | 11:48 PM
Joey Buentello's Avatar
Joey Buentello
so the sct is a diagnostic tool also?
Old Jan 31, 2011 | 11:50 PM
J415's Avatar
J415
Y'up...it's also a generic scanner.
Old Feb 1, 2011 | 09:01 AM
Annihilator_X9's Avatar
Annihilator_X9
BONUS! I wanted a scanner anyway. Might just HAVE to grab one of these now.
Old Feb 1, 2011 | 11:46 PM
CPTAFW163's Avatar
CPTAFW163
I highly recommend this product. If I had to choose only ONE thing in my sig, I would choose the SCT...EVEN OVER THE ACTUAL TRUCK!!!
But seriously, this SCT )From hemifever with HIS tunes) are the best.
True story:
I was driving the falimy back from a camping trip a month ago. My check engine light came on. I was thinking it was an "engine too cold for too long" code. I have a 180* thermostat, so it runs cooler in the winter. But this was my first winter with the 180* stat.
So, I was getting nervous. SO I took out the SCt and did a doagnostic scan. Found the code and searched it on my iphone. "Too cold for too long." I was with the family and I wanted to make sure it was nothing serious. ALso, there wa the "MSD ignition" code which does not activate a CEL (code that says the coil #1 is bad...does it for all trucks with a MSD box in it).
Really good product and if you get it from Sean (Hemifever) he will take care of you. Basically he is just like us.
