transmission will not shift into overdrive
Old Jul 9, 2019 | 09:31 AM
  #41
Eric Gavaletz's Avatar
Eric Gavaletz
Originally Posted by zman17
Check that fuse and swap the trans relay with the horn relay. If that doesn't cure it, then the OD/TC lockup solenoid unit is the most likely culprit.
Worked on mine thanks . Just jumped on here cause mine did the same thing this morning and I switched the relays and working great
Old Dec 23, 2020 | 02:15 PM
  #42
David Coffee's Avatar
David Coffee
Default ****ing problem
my shifting problem started between one light and the next was shifting as should put in nuetral then back to drive took off and no shifting at all
Old Dec 24, 2020 | 06:49 AM
  #43
Thomas bridges's Avatar
Thomas bridges
Freaking right im so tired of playing transmission roulette... I think I'm just going to take my 46re shell, buy the 48 internals and call it a day
Old May 3, 2023 | 11:44 AM
  #44
FixitAl's Avatar
FixitAl
Default Fuse for overdrive
Originally Posted by bjr1a
Are you sure there is not a blown fuse?...You have described the loss of voltage to transmission.......
Brian
where would that fuse be I'm having same issue
Old May 3, 2023 | 04:00 PM
  #45
In the Power distribution center, under the hood. Don't recall which one it is though.
