Leaking Metering Valve (Brake System)
Old Jan 30, 2011 | 05:46 PM
pioneerjrd's Avatar
pioneerjrd
Question Leaking Metering Valve (Brake System)
Hello, I am looking for some advice. I recently noticed that my truck (2000 Dodge Ram), kept on losing brake fluid and the level in the reservoir continued to go down. After doing some research, I found that the O-rings in the metering valve would no longer seal well and brake fluid was leaking out. Anyhow, I got the new part and installed it with no problems. My real question now, is bleeding the system. Since my truck has ABS, is there a special way or technique to bleeding the system or would it be just like when replacing a wheel cylinder or caliper? Any help would be greatly appreciated. Thanks...
Old Jan 30, 2011 | 06:12 PM
xjarhead69's Avatar
xjarhead69
Download this it should have the procedure in there.
https://dodgeforum.com/forum/2nd-gen...-gen-rams.html.
Dave
Old Jan 31, 2011 | 09:41 PM
pioneerjrd's Avatar
pioneerjrd
Thank you so much xjarhead69! This will help greatly.
