Beefing up spring load capacity of 1/2 ton springs
timbren. no change in unloaded ride height or quality. when you add load it sits on the rubber spring to pretty much eliminate squatting.
http://timbren.com/index.htm
I put in helper leaf springs when I had a camper. the reasoning was so I did not have to re-adjust my headlights when loaded (1200 lb camper?). they did help a lot with the squat but ride is rough. been thinking about pulling them as I no longer have the camper.
remember you are not raising axle capacity just keeping the truck level. they will break given enough weight.
sounds like you have been givin plenty of ideas to consider.
I put an add a leaf, air bags and sway bar on my 3/4 ton and that made the difference I needed for hauling my camper and trailer together and that camper is probably 3500lbs or more when loaded up.
Alot of guys swear by the Torklift Stable loads, or something like some Timbrens. The stable loads are kind of cool as they just make sure your overload springs kick in sooner and don't affect unloaded ride quality.
tomorrow eve I'll be installing the superlifts soft ride 3"+ leaves to replace my worn out and pretty much flat leaves and a 3" block.. - I'll give you a report.. they advertise increased load capacity and a progressive enough compression that the ride is just as soft as stock initially, but ramp up pretty quick to give you 1200lbs more capacity.. I'm suspicious of the increased capacity, but any improvement over what I have is better than none..
hungover as a mug, I managed to get the soft ride springs on..
My buddy took a picture, and when I get it I'll post it.. The stock springs were shot- laying them on the ground with 'bow' up, and laying the superlift springs beside them (with 3" blocks sitting atop the 'shot' springs) the superlifts springs were still about two inches taller..
I had to raise the torsion bars to level it out.. which is fine, because after the lift, the keys had almost no preload on them at all.. Now they do.. The truck sits level..
I haven't hauled or towed anything- but the difference in ride quality is really noticeable.. It's amazing how much of a role the rear suspension plays in overall handling.. AND- no 'squeak squeak squeak'.. I like that the most..
the only problem is, the truck is a lot higher than I originally planned.. I've raised it a total of seven inches now, all suspension.
