1500 Ram Lift Question! HELP!
Old Feb 1, 2011 | 01:29 AM
redheadhunter21's Avatar
redheadhunter21
I personally like body lifts because they have their uses, Performance Accessories all the way, there only just a tad over $200 maybe $250
Old Feb 1, 2011 | 07:38 AM
olyelr's Avatar
olyelr
Originally Posted by RamMXer711
Well I Do KNOW that worn out shocks can contribute to a lower ride height, and very stiff, taller shocks CAN raise your body away from the chasis. So in other words my shocks might even be worn out.
Ok. A quick 101 on the basics of lifting a truck, seeing how you are quite a ways from knowledgeable about it at the moment.
A suspension lift raises the frame (chassis) and body higher off the axles. Anything around 2-3" typically requires longer shocks, while anything over 3" typically requires several other parts as well (longer control arms, drop pitman arm, dropped track bar, etc...).
A body lift raises the body off the frame, leaving the frame in the original position it was before the body lift. These require no change in shocks or anything suspension related.
Shocks only control the bounce of the vehicle. Longer, stiffer shocks will only stiffen up your ride (and possibly be too long), they will not lift your truck. And half ton and 3/4 ton shocks are the same, theres no difference.
Old Feb 1, 2011 | 07:42 AM
HammerZ71's Avatar
HammerZ71
I dunno, I have a suspension lift on my current truck, but I've installed three body lifts on previous ones. Had a body lift with block and level combo on my 2nd Gen when I had it so it would clear 35s and had no issues. Often got compliments on the look of the truck. A little frame will show, but nowhere near as much as when I put body lifts on my Cheby trucks.
Suspension lifts are expensive (especially for an IFS truck, you guys are lucky not to have to deal with half shafts that require crossmember or sub-frame support). At some point the truck gets to the age that it's hard to justify sinking a lot of money into a lift or mods in general. I'd have no qualms doing an inexpensive body lift, especially on a truck over 10 years old.
Oh, and these guys are spot on, stiffer shocks only make for a firmer ride. It's coil spring height and stiffness that will effect how high your vehicle sits. Not uncommon for springs to sag over time.
Old Feb 1, 2011 | 08:58 AM
olyelr's Avatar
olyelr
After rereading what he wrote, I am thinking maybe he used the work "shocks" instead of "springs". That would make much more sense.
Old Feb 1, 2011 | 09:47 AM
Mad_Scientist's Avatar
Mad_Scientist
+1 thats what i got out of it too. I'd definately go suspension, you'd pay a little more, but i prefer function over price
Old Feb 1, 2011 | 11:23 AM
EricCartman's Avatar
EricCartman
Aren't the 2500 springs wider than 1500 springs? It would be more than a simple spring swap... new hangers welded to the frame and shackles...
Old Feb 1, 2011 | 11:28 AM
Silver_Dodge's Avatar
Silver_Dodge
Ya. Might as well put in the D60 with the new springs while your at it.
Old Feb 1, 2011 | 10:34 PM
RamMXer711's Avatar
RamMXer711
Yeah I guess the big torsion springs on the bottom aren't considered shocks lol. I apologize for the confusion, thats more of what I was getting at. Thanks guys.
