Lift question....
Old Feb 1, 2011 | 03:46 PM
dsertdog56's Avatar
dsertdog56
Originally Posted by tj941500
the tires were on the truck when i bought it and they are on the factory wheels.... they rub on the fenders when the wheels are turned all the way to either side...
Outer or inner fenders?
Old Feb 1, 2011 | 03:50 PM
tj941500's Avatar
tj941500
outer...
Old Feb 1, 2011 | 04:02 PM
dsertdog56's Avatar
dsertdog56
Outer? Interesting, especially with stock rims. What do they look like?
Got a picture? Pics are worth thousands of words!
Old Feb 1, 2011 | 04:50 PM
tj941500's Avatar
tj941500
Old Feb 1, 2011 | 04:53 PM
tj941500's Avatar
tj941500
the gaps in this pic are not adjusted,,,, but i have adjusted them since the pics,,,, the tires still hit,,,,
Old Feb 1, 2011 | 07:06 PM
dsertdog56's Avatar
dsertdog56
I shoulda been a but clearer...do you have a pic of the contact points...like the tire touching sheet metal?
Here's why...you'd be the first person I've seen that has that kind of contact with sheet metal with your combination.
Whats the actual tire size?
Old Feb 1, 2011 | 10:36 PM
tj941500's Avatar
tj941500
305 70 r16... i have the truck torn apart right now,,, fenders doors bed and hood are all off.... it will be a few weeks before any panels go back on... i am hoping to get the lift on before any body panels go back on... just because all the work is a bit easier to do
Old Feb 1, 2011 | 10:41 PM
tj941500's Avatar
tj941500
that should be just a little under a 33...
i was out messing around wit the truck... (moving it around in the garage)..... and i got to looking,,,, maybe the tire is hitting the control arm,,,, does that sound right??
Old Feb 1, 2011 | 11:35 PM
redheadhunter21's Avatar
redheadhunter21
control arm sounds right and to fix that you need wheel spacers or rims with less backspacing
Old Feb 2, 2011 | 09:36 AM
chastain90's Avatar
chastain90
All I have is a 2.5 in leveling kit from rough country. and I have 33 13.50s and they clear. My truck is also a off road edition so that helps a little. but all you should need is that 2.5 in spacer from rough country. only $100 and about 2 or 3 hours of work. Im about to get a 5 in long arm kit and might be getting rid of old suspension if theres any parts you might want.
