Lift question....
Old Feb 1, 2011 | 01:47 PM
tj941500's Avatar
tj941500
Default Lift question....
I have a 94 1500 project going on,, I want to raise it up a little bit,, I have 33" tires on it now but the rub,,, I have 3" blocks for the rear end... the front is where my question lays... Do I want to use 3" spaces in the front or should I do something else? I want the truck to set level and I dont want to have 500 bucks in just a 3" lift... so should I maybe go 3.5" or maybe 4" spacers???? If I go that high are my control arms going to be long enough or am I going to have to get new ones?? any info on this would be great.... thanks
Old Feb 1, 2011 | 01:54 PM
silver06cummins's Avatar
silver06cummins
This must be lift question week lol...If you have 3" blocks for the rear then you would need 4" spacers for the front, since the front end of 2nd gens typicaly sit about an inch lower than the rear, to level the truck up you need an inch taller for the front. I'm doing 3" front 2" rear myself over the weekend, and hoping I dont have to buy control arms, I have 33's on my truck and plan to keep them for awhile but 35's will clear with the correct BS on the wheels which im buying to!! Good Luck.
Last edited by silver06cummins; Feb 1, 2011 at 01:56 PM. Reason: typo....new keybard ad they're sticking lol
Old Feb 1, 2011 | 03:11 PM
tj941500's Avatar
tj941500
ok,,,,,, but does anyone know how high i can go before i have to worry about the control arms and the steering arm???
Old Feb 1, 2011 | 03:19 PM
zman17's Avatar
zman17
Retired Moderator - RIP
3"!!!!!!!!!!!!!!!!! For god sake do a search!
Old Feb 1, 2011 | 03:22 PM
slider15004x4's Avatar
slider15004x4
At 3" of lift you should use longer control arms, sway bar relocation bracket, drop pitman arm and track bar relocation brackets. You can get away without using them but your geometry is going to be messed up and I wouldn't recommend it.
Old Feb 1, 2011 | 03:31 PM
tj941500's Avatar
tj941500
i did do a search and every one you have to read through 3,4,5,10,or 15 pages of crap that has nothing to do with the original question.. i just wanted a quick answer.. im sorry for the inconvenience... but remember your the one that clicked on the thread dumba**
Old Feb 1, 2011 | 03:32 PM
tj941500's Avatar
tj941500
silver06 and slider1500,,,,, thank you for the info...
Old Feb 1, 2011 | 03:34 PM
dsertdog56's Avatar
dsertdog56
My question is where do they rub. Lifting a truck doesn't always clear up rubbing issues...
When you add lift to the front axle of your truck you change the geometry of the control arms and track bar. This moves the axle backwards in the wheel well and uncenters it under the frame. A good rule of thumb is about 3/4" in movement for every 2 inches of lift.
Most rams can run a 33inch tire on factory rims without clearance problems. Many can run a 2 inch spacer and still clear the arms at full lock. Some don't, but I wonder if installing or adjusting thier steering stops would fix that.
If you want the truck "level" I would use a 2 inch front spacer. Nothing in the rear. Your truck should have enough slack in it to reset the caster.
Old Feb 1, 2011 | 03:35 PM
zman17's Avatar
zman17
Doing a search entails reading through "3,4,5,10,or 15 pages of crap". Which Is too much for some one who is too lazy!
Old Feb 1, 2011 | 03:38 PM
tj941500's Avatar
tj941500
the tires were on the truck when i bought it and they are on the factory wheels.... they rub on the fenders when the wheels are turned all the way to either side...
