Problems on a 95.... And stumped....
Old Feb 2, 2011 | 09:12 PM
Swatkins13's Avatar
Swatkins13
Default Problems on a 95.... And stumped....
'95 Ram, extended cab
5.9 Magnum
My wife managed to blow the head gasket. Had it fixed by the local mechanic. Now, it begins shaking at 45mph until I reach 65. The gas milage is HORRIBLE. I know its big truck, but when I got it it would do 16-18 mpg, now I average about 5-6 mpg.
What the hell did he do to my truck?
Old Feb 2, 2011 | 09:50 PM
Swatkins13's Avatar
Swatkins13
I did check the mass air sensor, it wasnt even hooked up. I plugged it in and helped a little for the mpg, but nothing else.
And if I turn the overdrive off, the shaking stops.
Old Feb 2, 2011 | 10:28 PM
Ugly1's Avatar
Ugly1
Codes?
flip the ignition on 3 times to the run position and back off real quick 3 times leaving it in run after the 3rd. Then count the groups of engine light blinks. Those are the codes.
Old Feb 2, 2011 | 10:29 PM
99dodge318's Avatar
99dodge318
almost sounds like (just my opinion) your torque converter is going out
Old Feb 2, 2011 | 10:31 PM
Or, a miss. Right around 45 mph, the torque converter clutch locks up, and if you have a miss on one or more cylinders, you REALLY feel it then.
Check plug wire routing.
