E fan set up
Old Feb 5, 2011 | 09:46 AM
97Rampowerhouse's Avatar
97Rampowerhouse
Default E fan set up
Hey guys I got my dual E fan set up for my truck from J415 yesterday!
I want to know if its better to leave the shroud on with the E fans or keep it off? Not really sure if leaving it on would help pulling the air into one spot, or if its off if it will just blow the air everywhere. I want the truck to run cool but at the same time I want more room!
Old Feb 5, 2011 | 10:10 AM
Salex007's Avatar
Salex007
only good thing about shroud is that you get to keep coolant and washer bottle
Old Feb 5, 2011 | 10:18 AM
97Rampowerhouse
I could just zip tie them to the core support right
Old Feb 5, 2011 | 10:20 AM
snakeman's Avatar
snakeman
I am also installing dual fans this weekend. I sure could use some help with what circuits to wire everything to. I am going to experiment on cutting up the shroud to hold the overflow bottle. I will post pics if it works out.
Old Feb 5, 2011 | 10:29 AM
Salex007's Avatar
Salex007
most people just cut up shroud anyways, that would be a lot of weight then on the radiator if you are zip tying everything to it as it isnt designed to hold all that weight
Old Feb 5, 2011 | 10:35 AM
97Rampowerhouse
zip tie them to the core support I would never zip tie anything to my radiator
Old Feb 5, 2011 | 11:04 AM
dipsherry's Avatar
dipsherry
i left my shroud off... i miss my table for holding my ratchet and wrenches... but i have yet to overheat. Which is nice. and the lil mpg boost sure was nice
