P0305 code every now and then??
Old Feb 6, 2011 | 10:41 PM
dledger71's Avatar
dledger71
Default P0305 code every now and then??
I have a 2001 with a 5.9 in it and twice in the last 2 weeks it has showed a P0305 code. 4-5 days after the code shows, it goes away for a few days. Is there something that could be throwing this code? I am not doing any rough or off road driving when this happens. Just normal city driving.
Any help please...
Thanks
Old Feb 6, 2011 | 11:10 PM
jasonw's Avatar
jasonw
Site Moderator
PO305 stands for misfire in cylinder #5. When was the last time you changed your spark plugs, wires, and/or distributor cap/rotor?
Old Feb 6, 2011 | 11:17 PM
dledger71's Avatar
dledger71
I just bought the truck and the guy said that he changed the plugs about 6 months ago. As far as the wires, cap and rotor I am not sure... I dont remember what he said.
Old Feb 7, 2011 | 02:20 AM
Mad_Scientist's Avatar
Mad_Scientist
Generally all of those are done together (or at least plugs and wires). First thing i'd do is make sure #5 (should be drivers side 3rd one back) spark plug wire is pushed on there nice and tight (both at the plug and distributor end) .
If it continues, I'd pull that plug to see what it looks like and go from there. Possibly inspect the wires to determine their age (though thats always more of a guesstimation) to see if the previous owner replaced them with the plugs or not.
Old May 13, 2011 | 08:36 PM
TLars's Avatar
TLars
Checking threads on this as I'm experiencing this AGAIN! Other than cylinder heads, the truck just received all new components - cap/rotor/wires/plugs, plenum repair & mod, water pump, timing set, new front O2 sensor, dual exhaust, spectre CAI and I run premium with Superchips programmer. It was running fine, now getting P0305 code coming up. I will clear it and it will run for about 1-2 weeks then come up again. I've dumped so much money into this truck after a new tranny - what the heck is it now?
Old May 13, 2011 | 10:43 PM
Swap injectors for cylinder five and seven. Clear the PCM, and drive it. See which cylinder comes up with it next.
