Old Aug 14, 2015, 02:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brake Guides
Print Wikipost
Brake problem, huge problem! 2001 Ram
Old Feb 10, 2013 | 04:20 PM
  #21
Matthew Morris's Avatar
Matthew Morris
yes, and the abs lite is on. We r gonna try to swap out the calipers again with another set and we think that it will fix the problem cause they r reman calipers.
Old Feb 10, 2013 | 04:33 PM
  #22
gdstock's Avatar
gdstock
Cailpers may not be the problem. Proportioning valve needs to be reset to center.
Old Feb 10, 2013 | 05:38 PM
  #23
h3lzsn1p3r's Avatar
h3lzsn1p3r
the issue is porpotioning valve clearly pump the brakes and push the pin on the porpotioning valve it should center you may need to bleed front brakes agian after resetting it
Old Mar 20, 2013 | 08:41 PM
  #24
jon1090's Avatar
jon1090
Default same brake problem
i just replaced the calipers and pads didnt work replaced the master after bench bleeding still pedal went to floor after bleeding all sides.. also the brake and abs light was on i did rear brakes shoes and wheel cylinders rear brake lines no leaks bled again still same problem im thinking next is some ABS issue.. but im kinda confused on what you did
Old Mar 20, 2013 | 09:03 PM
  #25
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
If it's still going to the floor I would suspect rear wheel cylinders or a bad master.
I had TWO bad masters in one shop visit, both were remans. A NEW master and I was good to go.
Got the new one for the price of a reman too.
Old Mar 20, 2013 | 10:11 PM
  #26
jon1090's Avatar
jon1090
nothings leaking and ya i tried the reman also lol and than i just bought a new one re bled the MC and is still going i believe i have same problem with that abs system
Old Mar 20, 2013 | 10:16 PM
  #27
gdstock's Avatar
gdstock
Proportioning valve....
Old Mar 20, 2013 | 10:20 PM
  #28
RWAL, or 4WAL?
Will the brakes pump up?
Old Mar 20, 2013 | 10:36 PM
  #29
jon1090's Avatar
jon1090
im pretty sure its RWAL, i looked in the MC after and i saw a few lil specs of black so i took it out, like what 25xs said, the brakes do pump up and hold with light pressure untill u start the car than down she goes
Old Mar 20, 2013 | 10:37 PM
  #30
jon1090's Avatar
jon1090
it seems like when i bled the rear the peddle had gotten tighter than i went to do the front and felt the peddle back to spongy
