EVAP Emission control system leak
Old Jun 21, 2005 | 10:38 AM
jay6ird's Avatar
jay6ird
Default EVAP Emission control system leak
Getting check engine codes P0442 & P0455 on my 01 RAM. I tightened gas cap and messed with the evap hoses but could not find anything. What could it be. I reset the codes by disconnecting the battery and they came back after 40 miles.. How long does it take for a code to re-occur??
Thanks
Old Jun 22, 2005 | 01:46 PM
steve05ram360's Avatar
steve05ram360
Default RE: EVAP Emission control system leak
there is a canister under the bed of the truck, mounted to the frame, you may have damaged it or one of the vacuum lines going to it. If you wheeled it at any time, it is possible it got damaged. If your truck is setup like mine, there is next to nothing in the way of vacuum lines, disconnect them from the intake manifold and put a vacuum guage on them and see if they hold a vacuum. if not, you probably have a leak somewhere...
Old Jun 22, 2005 | 02:06 PM
greenmachine's Avatar
greenmachine
My mom, yes my mom, had the same thing happen to her and all it was was a small piece of vacuum hose.
Old Jun 23, 2005 | 05:09 PM
jay6ird's Avatar
jay6ird
Well, I tried to check all the hoses and make sure they were tight. Also cleaned gas cap and top of filler tube. The green cap with the valve under it in the engine area near the canisters was tightened then I reset the battery so we will see how long it lasts..
Old Jul 1, 2005 | 12:09 PM
jay6ird's Avatar
jay6ird
so far it has been 200+ miles and no code...
Old Jul 6, 2005 | 10:09 AM
jay6ird's Avatar
jay6ird
Well 337 miles and the check engine light returned. Guess I will have to buy a vacume gauge and check things out.
Old Jul 17, 2005 | 11:22 PM
snakebit95's Avatar
snakebit95
I recently had the same codes on my wife's Durango. I inspected all the vacuum lines between the gas tank and the engine, and found a 1" diameter line was split at the very top on the connection near the front of the gas tank. You would have never known it was split without lightly pulling on the line. The line popped right off. The split was long enough, that I know it had to be leaking there. I just trimmed the split portion off and reinstalled it. I added a hose clamp to the line this time; which might help it last longer. Take a look at yours and see if this is the same problem. Hope this helps!!
Wayne
Old Jul 21, 2005 | 01:25 PM
jay6ird's Avatar
jay6ird
Well instead if a vaccum gage I got a new gas cap and it has been good over 600 miles. This may have been it. I will report back if it fails.
Old Jul 21, 2005 | 02:09 PM
steve05ram360
ORIGINAL: jay6ird
is that stupid or what? a gas cap causing all your grief. why cant they come up with a code that points to the gas cap?
Old Aug 4, 2005 | 11:12 AM
jay6ird's Avatar
jay6ird
$12 dollar gas cap was the fix. Has been good for 3k miles.
