Water Pump or Fan Clutch? Or Neither?
Old Feb 8, 2011 | 09:17 PM
kazslo's Avatar
kazslo
The paper one that came with it, after the fact I imagine its better to just go get a new good one?
Old Feb 8, 2011 | 11:02 PM
jasonw's Avatar
jasonw
Site Moderator
If you have to do it again, yes, I'd go nab a Felpro gasket. Awesome gaskets.
Old Feb 9, 2011 | 07:21 AM
dhvaughan's Avatar
dhvaughan
secret trick to try.
remove the long bolt where the leak is. coolant will run out, so be prepared.
coat the threads with rtv and reinstall. torque to spec.
it might fix it.
Old Feb 9, 2011 | 04:35 PM
PurplDodge's Avatar
PurplDodge
I have bought a water pump from every parts store in town (Advance, NAPA, AutoZone) over the past few years, as I go through a water pump about every 30,000 miles. NONE of the gaskets that came with those pumps matched up at all with the old pump, the new pump, the old gasket, or the engine. The gaskets that come with the pumps are absolute **** and do not work on our engines. Why this is like this, I have no idea. Get a Fel-Pro gasket, its the right one for the job.
Old Feb 9, 2011 | 08:19 PM
kazslo's Avatar
kazslo
Thats what I ended up doing - I slipped in a new gasket (the paper one was all out of wack), and smothered the bolts in sealant. No leaks!
Old Feb 9, 2011 | 08:29 PM
PurplDodge's Avatar
PurplDodge
Good boy, now since I see you are in Mexico, get us some pics of a 2nd gen Ramcharger!
