285's vs 265's
Old Feb 9, 2011 | 02:13 PM
mikentiff's Avatar
mikentiff
Default 285's vs 265's
I have 285's on my truck now and everytime i go up a hill it shifts out of overdrive. If I go back down to 265's will it make a big difference in that or not much ?
Old Feb 9, 2011 | 02:38 PM
BIGBIRD85's Avatar
BIGBIRD85
now it did with mine. i have a 5.2 and then i found out i had a bad govenor pressure solenoid and sensor.
Old Feb 9, 2011 | 02:42 PM
drewactual's Avatar
drewactual
define "shifts out of overdrive".. if you mean the tranny kicks down to third gear, that's one thing- if you mean the O/D OFF light comes on AS it shifts down to third- that's quite a different thing, and indicative of something NOT right in your tranny..
If you mean it just kicks down, I could see the extra drag of the wider tire causing you issue.. There are a lot of folks a lot smarter than me that will chime in soon..
Old Feb 9, 2011 | 02:49 PM
jasonw's Avatar
jasonw
Site Moderator
Not that I've seen. I currently have 265s, and before the SCT, CAI, Fastman, and exhaust, it was kicking down for hills for me to. Now only the steeper ones make it kick down.
I didn't do individual test runs to see which upgrade had the most effect on the power up hills, but if I had to guess, I'd say the CAI and the SCT. The rest certainly helped though.
Better gears (gear ratio) would also help.
Old Feb 9, 2011 | 03:03 PM
mikentiff's Avatar
mikentiff
I mean it down shifts when I go up a hill like when it's in cruise control in will down **** and it's like you stopping the gas
Old Feb 9, 2011 | 06:02 PM
Randy_W's Avatar
Randy_W
The taller tires change your effective gear ratio by .20 give or take, that's noticeable and the added unworthy weight makes a difference, when you add the two, unless you have monster torque, you're gonna feel it.
Old Feb 10, 2011 | 02:47 AM
mikentiff's Avatar
mikentiff
So me going back to 265's will help with the power, my mpg, and save my tranny ?
Old Feb 10, 2011 | 07:53 AM
Randy_W's Avatar
Randy_W
It will help in all those areas, yes.
Old Feb 10, 2011 | 11:10 AM
99dodge318's Avatar
99dodge318
it will also save your front steering componets. thats something im dealing with right now
