Iac
Old Feb 10, 2011 | 01:55 PM
cmares's Avatar
cmares
Default Iac
If I take an IAC off to clean it, what position should the valve be in? Open or closed? How can I tell if it is sticking open?
Old Feb 10, 2011 | 05:50 PM
jasonw's Avatar
jasonw
Site Moderator
Your truck will have problems maintaining idle speed if its stuck open/closed. Do not try to adjust the plunger on the IAC manually (with your fingers), you will break the IAC if you do that.
Old Feb 10, 2011 | 05:52 PM
take it out, carefully clean everything, put it back in, disconnect the battery for a few minutes, start the truck, and let it re-learn the idle.
When the PCM is reset, it 'forgets' where the IAC was, so, it will run it all the way in, to get a new zero reference for it. Just give it a few to relearn idle. No worries.
