Steering question..
Old Feb 12, 2011 | 09:31 AM
dhvaughan's Avatar
dhvaughan
check your air pressures. the new tires might be load range D or E and rated for about 65-80 psi and the shop might have put in that much air.
don't exceed the max psi on the side of the tire, but i wouldn't run more than about 45-50 psi for unloaded daily driving. air up as needed for hauling or towing or better mpg.
higher air pressures make the truck light and skatey feeling.
Old Feb 12, 2011 | 08:52 PM
Jackstand123's Avatar
Jackstand123
Thanks for all the suggestions.. They are load E as I have 55 psi in them... The trac bar is new a stock one.. The old tires I bought at about 75 % . The old tires are the exact same every thing except being brand new this go around!
Old Feb 12, 2011 | 08:57 PM
zman17's Avatar
zman17
Retired Moderator - RIP
How much play does the steering wheel have before the tires actually move?
Old Feb 12, 2011 | 09:05 PM
Jackstand123
Not much play before.
Just more noticeable. Now.
Old Feb 12, 2011 | 09:19 PM
zman17's Avatar
zman17
As previously stated, I'm leaning towards alignment also. Just because it is within specs doesn't mean it right(which is where most places will leave it). If you do a search here, you'll find some specs that are recommended over OEM specs.
Old Feb 12, 2011 | 11:27 PM
mikentiff's Avatar
mikentiff
I replaced the trac bar( as a shop told me mine was bent and that was the problem) and still the same prob. I was pissed so i took to it to different shop and they said the steering box was worn out so they replaced that and guess what the same freakin thing. I had an allignment also and still nothing. People said it's because I have mud tires, but not sure that it would be that because when I bought the truck it had dunlop a/t's and guess what lol same thing!!!!!
Old Feb 13, 2011 | 11:12 AM
The reman boxes can be just as bad as the stock one that was in there.....
Grab a friend, and do your own inspection. See what moves when it shouldn't, or, what doesn't move when it should....
Old Feb 13, 2011 | 12:01 PM
jasonw's Avatar
jasonw
Site Moderator
Not cheap, but there is always...
http://www.streetperformance.com/spe...ation=borgeson
