Truck hesitating ?????
Old Feb 13, 2011 | 09:45 AM
mikentiff's Avatar
mikentiff
Oh I forgot to metion that every once in awhile the ceck light will flash for a couple seconds then stays on
Old Feb 13, 2011 | 09:54 AM
What codes ya gettin'?
Might wanna replace the O2 sensor just on general principles......
Old Feb 13, 2011 | 09:58 AM
mikentiff's Avatar
mikentiff
Misfire on 4 cylinders I don't remember which ones but it was both sides. Why would the CEL flash ?
Old Feb 13, 2011 | 10:00 AM
CEL flashes when cylinders are misfiring. If they misfire often enough, it sets a hard code. (at least, that's how the GMs worked......)
If you are getting a random misfire code as well, might be time for a tune up. When mine was doing that particular trick, the dist cap and rotor were in pretty bad shape.
Old Feb 13, 2011 | 10:02 AM
Annihilator_X9's Avatar
Annihilator_X9
Any knocking or pinging? Have you tried rerouting the wires according to the TSB in the FAQ?
Old Feb 13, 2011 | 10:12 AM
mikentiff's Avatar
mikentiff
already did a tune up
Old Feb 13, 2011 | 10:18 AM
Check plug wire routing is suggested above then.
Old Feb 13, 2011 | 10:22 AM
mikentiff's Avatar
mikentiff
but my thing is the wires weren't routed like this from the factory so why would you change them ?
Old Feb 13, 2011 | 10:24 AM
Were the wires you replaced factory wires??
TSB came out after the trucks had been on the market for a while, to correct misfire problems associated with the plug wires engaging in a bit of "cross talk".
What flavor of plug wires did you get??
Old Feb 13, 2011 | 10:58 AM
mikentiff's Avatar
mikentiff
autolite I want to say
