5.9L head gaskets...
Old Feb 15, 2011 | 01:35 AM
96smokestack's Avatar
96smokestack
Originally Posted by dhvaughan
head bolts - ok to reuse.
DO NOT reuse head bolts! They warp/stretch/bend over time. Spend the extra money and get new ones.....
Old Nov 13, 2013 | 11:59 PM
kdizzle929's Avatar
kdizzle929
Default Head removal and gasket replace helllllp
96 ram 1500 5.9l just checked head gasket blown whats the easieast way to fix?
Old Nov 14, 2013 | 08:25 AM
dhvaughan's Avatar
dhvaughan
the EASIEST way is to try the liquid glass repair product. sometimes it works, sometimes not. if not, you're not out a lot of time or money.
the right way is to remove the head(s) and take them to a machine shop to be magnafluxed for cracks. or visually inspect and see cracks between the valve seats and replace them with new loaded heads from Clearwater or other. resist any urge to repair cracked stock heads. they're likely to crack again in the same place, or somewhere else.
Old Nov 14, 2013 | 08:27 AM
AtomicDog's Avatar
AtomicDog
No issue with re-using the head bolts on the 5.9 engines. When I replaced the head gaskets on the motor I swapped into my truck, I re-used the head bolts with no issues. I did run a bottoming tap thru all of the threaded bolt holes in the block to ensure good thread engagement and accurate torque readings. I also cleaned up the old head bolts threads with a thread die, too. Been running that engine now for the past few years with no issues at all.
