aluminum drive shafts on the F150
Old Jun 22, 2005 | 03:38 PM
steve05ram360's Avatar
steve05ram360
Default aluminum drive shafts on the F150
poking around in the wrecking yard last week I came across a couple of DS's that were aluminum... finally found out that they came from the F150... thought this was interesting and wonder why no-one makes a alum DS for the dodge...
Old Jun 22, 2005 | 04:33 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: aluminum drive shafts on the F150
Are you sure they didn't come from Ford Lightnings? I know the original Lightning (pre-supercharged) had an aluminum shaft. The new SRT-10 Ram also has an aluminum shaft.
My guess as to why nobody makes one, is that there isn't any demand for them. I don't know of a lot of people that have broken the stocker, even the guys running "bombed" CTDs or heavily modded V10s. It's not the weak link in the driveline. They're also damn expensive! []
If anyone was really interested in one, there are several shops out there that could custom make one.
Old Jun 22, 2005 | 06:45 PM
steve05ram360
the idea behind it is better throttle response. less rotational mass to get spinning. plus weight reduction is an added bonus. every pound you can shave off your ride = better throttle response and higher power to weight ratio...
Old Jun 22, 2005 | 06:48 PM
steve05ram360
I stand corrected...
http://www.dennysdriveshaft.com/html/4x4_off_road.html
makes aluminum shafts... just need to have it spec'ed out and built.
ramfan5.9's Avatar
ramfan5.9
and alluminum doesnt rust
Old Jun 22, 2005 | 07:14 PM
greenmachine's Avatar
greenmachine
If I am not mistaken Chevy also runs some aluminum. Those may have been aftermarket??
Old Jun 22, 2005 | 10:58 PM
steve05ram360
the ones in the wrecking yard couldnt have been aftermarket, there were 3 or 4 of them. I doubt the chevy ones are too, they are most likely coming from the factory like that.
