Transmission help
Old Feb 15, 2011 | 09:03 PM
ptgo's Avatar
ptgo
Default Transmission help
Hi this is my first post I need help with transmission. It may be here on here but I cant find it I have 1997 ram 2w.d. 3.9 has a 42 re out of a wrecked 01 ram 1st thru 3rd are perfect guy I got it from said it worked great looks as if it had been rebuilt their was no metal or clutch material in pan and fluid was clean. So here is how it go's start off goes in drive fine shifts great about the the time trans fluid reaches temp OD. light comes on never shifts into OD. I cant find info on how to test elec. side of trans.
So any HELP would be greatly appreciated also does any one know were I can get a new t.V. cable parts stores dont have. Thanks I hope one day I can help someone out
Old Feb 15, 2011 | 09:46 PM
Mad_Scientist's Avatar
Mad_Scientist
It would be easy to drop the pan and clean it prior to sale to give the impression that the tranny had been rebuilt.
Does the check engine light come on, or the O/D off light?
If it's check engine: take it to orielly's (autozone, advance, whatever) and get the code read (free), then post it here so people will have a better idea of whats going on.
If it's O/D off: I've heard of situations similar to this where that light will come on indicating something wrong with the tranny/pcm match-up (such as putting a 42rh where a 42re should go, or vice versa).
As for the tv cable, it's a dealer only part (cost me $50 when mine snapped)
I usually try to abstain from being a grammar **** on the internet, but a few more periods/commas (in the right places) and separating your thoughts/questions into different paragraphs would tremendously help in getting your point across. I had to reread your post 3 times to fully understand what was going on. Slow down and think about what you're typing.
Oh yeah, and what the hell do you mean by temp O/D?
Old Feb 15, 2011 | 09:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The OD will turn off if the tranny is overheating.
Old Feb 15, 2011 | 09:58 PM
Mad_Scientist
Didn't know that, but it is another likely possibility (wouldn't trans temp light come on too though?). If this is the case it's likely due to a clogged check valve.
Old Feb 15, 2011 | 10:23 PM
zman17's Avatar
zman17
The temp light should go on if it is truly overheating. Anything is possible with these thing though. The Gov. Pressure Switch/Transducer would be my next guess. Bottom line is, it needs to be put a scanner capable of monitoring the tranny.
Old Feb 15, 2011 | 10:53 PM
UnregisteredUser's Avatar
UnregisteredUser
Overdrive is disabled at around 240 degrees, Trans Temp light comes on at 260. Could be you're hovering in the middle there, which ain't good at all.
Old Feb 16, 2011 | 09:29 PM
ptgo's Avatar
ptgo
Hi Im sorry for the gramer Im not very good at it. As for the trans I dont think that the person I got it from lied. He had a lot of service records and the truck was nice minus the wreck damage all the fluid that was in it converter ect. was clean. The trans is a 42RE got the number at pan rail,no check engine lights or codes, have not seen any kind of trans temp light checkvalve has been removed. "od temp" When the trans. temp gets above min. temp as to were it would shift in OD. dash light comes on. What type of scanner would I need to get?
Does anyone know how you test od solenoid. Thanks {Im trying to learn how to navigate this site}
Old Feb 16, 2011 | 10:03 PM
zman17's Avatar
zman17
This might help, http://www.socaldieseltrucks.com/for...roubleshooting
Old Feb 17, 2011 | 09:21 PM
ptgo's Avatar
ptgo
Hi to all thanks for all the info "and the link Zman" weather should be good this weekend will do some more work with all the new info. I will let you know what
happens.
