I need some help PLEASE!!!
Old Feb 17, 2011 | 05:17 PM
99podge's Avatar
99podge
Originally Posted by zman17
The p0740 is most likely the result of a faulty TClockup / OD solenoid assembly.
My trans shifts nice and clean, fluid is good and clean since I put the trans in 2 months ago, and its at a good level. Goes into overdrive as it should. Thanks for the input, just need to figure out this ticking thing, I got a video of the tik and ill try to put it on the forum if i can figure it out. lol
Old Feb 17, 2011 | 05:51 PM
UnregisteredUser's Avatar
UnregisteredUser
If you suspect an injector, take a noid light and stethoscope to it, and compare to some other injectors so you know what "right" looks and sounds like and can determine if #1 seems not right.
Another logical approach: First the easy and free part: Swap spark plugs #1 and #3, and spark plug wires #1 and #2, then clear your DTC's. When the code returns, see if it followed the plug or the wire, or stayed on #1. If it followed the plug or wire, replace the part it followed. If it didn't move, the next step is to swap injector #1 for #5, clear DTC's, and see what happens.
If the misfire stays with #1 after that, you've got a deeper mechanical problem.
Old Feb 17, 2011 | 06:40 PM
99podge's Avatar
99podge
Well then gentleman either im the dumbest person in the world, or just didnt think of the most simplest thing, was taking a video of the tik and what not and I was wiggling the injector connecter, and then wiggled the cyl #1 spark plug wire started to tik worse, lol wow the spark plug boot wasnt on all the way, but had to push on it really hard to get it to snap on. Not 100% sure if thats the problem but most likely, going to get new wires there getting a little old. But thank you guys very much for your patience and cooperation!
Old Feb 17, 2011 | 07:30 PM
UnregisteredUser
Dat would splain it. Let us know how it goes, huh?
Old Feb 17, 2011 | 07:49 PM
99podge's Avatar
99podge
I really had to push on the boot to snap on the spark plug, I think the little metal connector is messed up.
