power lock d70 diff ?
Old Feb 20, 2011 | 07:17 PM
donnyonit's Avatar
donnyonit
Default power lock d70 diff ?
i'am looking for some info on the d70 power lock (posi) rear end. i have 3.54 gears and want to switch to 4.10 ratio. i found a carrier for 4.10 with no guts. can i transfer the side gears ,spiders and clutches from the 3.55 carrier to the 4.10 carrier. i have a 98' and the 4.10 is 99'. do dodge d70 come with different kinds of carriers for posi or are they all the same (power lock)?
Old Feb 20, 2011 | 08:40 PM
donnyonit's Avatar
donnyonit
from what i can tell i wont need a new carrier to switch to 4.10 gears from the 3.54.
Old Feb 21, 2011 | 02:51 AM
99dodge318's Avatar
99dodge318
if your truck is 4wd you need to find matching gears for the front or remove the driveshaft.
Old Feb 21, 2011 | 04:23 AM
Kraiger's Avatar
Kraiger
For dana 70 the carrier is good from 3.54-4.10. 99dodge318 hit the nail on the head with the front gear swap too. If you want it to lock more and stay locked i suggest going to the dealer and getting a rebuild kit for the limited slip. They come with a shim pack and just use the thicker shim with asembling.
Old Feb 21, 2011 | 09:22 PM
VEETEN's Avatar
VEETEN
From what I have read
Dana does have different carriers, but from what I can see all D70 from 94-01 use the Power-lock or standard diffs, D44,D60and D80 use Trac-lock or standard diffs.
The diff housing needs to be changed when switching between trac and power lock.
Dana made changes, the 94-98 and 99-01 are different on a couple of things, but the diff seems to be the same.
