Different plugs
Old Feb 21, 2011 | 07:08 PM
mooseguy's Avatar
mooseguy
Default Different plugs
1996 Dodge Ram 1500 4x4 ... 5.2 ... engine .....NGK... Champion... Just back from my newphews shop hes a heavy duty diesel mech we checked for head casket/block leak none too be found also no steam in shop when revving motor all said and done I decided too check my new plugs they seemed find only then when comparing too old plugs I had removed 2 months before only then realized old plugs are NGK and the plugs I replaced them with are champion does this make a difference gonna re-route wires tomorrow just wanna check the plug issue ...
Old Feb 21, 2011 | 07:26 PM
matty675's Avatar
matty675
champion or NGK, both good
Old Feb 21, 2011 | 07:28 PM
zman17's Avatar
zman17
Retired Moderator - RIP
So are periods and comma's.
Old Feb 21, 2011 | 07:32 PM
matty675's Avatar
matty675
HAHAHAHA he has about 20 periods, but in all the wrong places.
Old Feb 21, 2011 | 07:53 PM
mooseguy's Avatar
mooseguy
Never knew that periods and comma's made a difference when asking a question.Hahaha just a little habit I got into when playing crib on the net. I like to thank you for all your helpful information , if this problem isn't fixed by weeks end , then the scrap yard will be her last destination.
Old Feb 21, 2011 | 07:58 PM
zman17's Avatar
zman17
"Never knew that periods and comma's made a difference when asking a question."
Make's a difference to the person trying to read it.
BTW, maybe you should tell us what the problem is you are having.
Old Feb 21, 2011 | 08:47 PM
VEETEN's Avatar
VEETEN
What is the problem?
Old Feb 21, 2011 | 08:57 PM
mooseguy's Avatar
mooseguy
1996 Dodge Ram 1500 4x4 , 5.2 Around town shes great on the highway about 50 or 60 kms into the trip she'll lose power...start popping noise from carb area then missing on more than one cylinder got her back too the garage not long after she did this they ran a code check. It was missing on 3 cylinders the truck code says code 43.This problem started about 2 weeks ago since then I have replaced,plugs,wires,ignition coil , crank sensor and cam sensor,dist and rotor , but it continues the same at about 50 kilometers into trip , already spent alot of money on parts , computer checks and mech/garage time did a wire test from coil to computer thats fine.Going re-route plug wires tomorrow , the garage mech is now telling me the truck computer is finish and too replace it , Don't understand how come this problem is so hard to find and fix.
Old Feb 21, 2011 | 09:01 PM
lastrights's Avatar
lastrights
i pinged really bad with NGK iridium IX plugs, changed to the autolights 3923 and its running like a beast ! !
Old Feb 21, 2011 | 09:24 PM
zman17's Avatar
zman17
Have the cat tested.
