head lamps
Old Feb 20, 2011 | 08:32 PM
fattmann's Avatar
fattmann
Default head lamps
I have a 2001 Ram 1500. My question, is there a place where the headlamp harness unplugs from main harness? If so, would it be possible to get the sport lamps(the one with2 bulbs) and the headlamp harness from scrap yard. And replace the one lamp headlights?The head lamps on this truck produce almost no light. Even with the high dollar sylvania bulbs.
Thank You
Old Feb 20, 2011 | 09:16 PM
PurplDodge's Avatar
PurplDodge
You could just do this...Because swapping harnesses would require disesction of the PDC, and that aint fun.
http://www.amazon.com/1999-DODGE-CON...=1DBGRNQH8FCBS
Then do the headlight re-wire by jasonw that is in the DIY links thread in the FAQ section.
Old Feb 22, 2011 | 12:09 AM
fattmann's Avatar
fattmann
Default thanks and one more question
Product Description
THIS IS A BRAND NEW KIT TO CONVERT YOUR REGULAR RAM TRUCK TO RAM SPORT HEADLIGHTS. CONVERT YOUR RAM 1500 2500 3500 INTO A DODGE RAM SPORT. THIS IS FOR YOUR DODGE RAM 1500 FROM 1999-2001 AND YOUR DODGE RAM 2500/3500 1999-2002 INTO THE DODGE RAM SPORT HEADLIGHTS. THIS KIT INCLUDES BOTH LEFT AND RIGHT CLEAR SPORT HEADLIGHTS, CORNER LIGHTS, BRACKETS, RUBBER GASKETS AND 2 CONVERSION HARNESSES. THIS KIT IS A PLUG AND PLAY CONVERSION. GET THESE LIGHTS NOW AT A FRACTION OF THE COST OF FACTORY ONES, UPGRADE YOUR DODGE RAM TRUCK INTO A RAM SPORT WITH THIS GREAT CONVERSION KIT.
Thank You, but I have a question..(says plug and play) why would I then need to do a rewire like is told in FAQ??
Thanks
Old Feb 22, 2011 | 06:44 AM
PurplDodge's Avatar
PurplDodge
Read it, in layman's terms, it makes your headlights brighter:
https://dodgeforum.com/forum/2nd-gen...mp-relays.html
