Transfer case switch, and general questions
Old Feb 20, 2011 | 11:13 PM
byronpen's Avatar
byronpen
Default Transfer case switch, and general questions
OK a few question for you all. I bought my new transfer case, it a np231-hd, can anyone tell me what makes it heavy duty.
ok, what dose the transfer case switch do, my truck is vacuum, and the hoses are all tore up, can anyone point be to how to reinstall them, in the right order. Last question can you drive the truck with the hoses all tore up. and the vacume lines not working, And what will happen if you do.
Old Feb 21, 2011 | 07:58 AM
97tn4x4's Avatar
97tn4x4
I'm not sure what makes it "heavy-duty" but as far as the lines go there should be 4, a red, black, green, and gray. The red and black ones go to the actuator on the front axle and the green is just a vent and the gray one supplies vaccine from motor. It hooks up on the passenger side rear of the motor. I actually made a similar post sometime back and if you can search my threads zman
Old Feb 21, 2011 | 07:59 AM
97tn4x4's Avatar
97tn4x4
I'm not sure what makes it "heavy-duty" but as far as the lines go there should be 4, a red, black, green, and gray. The red and black ones go to the actuator on the front axle and the green is just a vent and the gray one supplies vaccine from motor. It hooks up on the passenger side rear of the motor. I actually made a similar post sometime back and if you can search my threads zman posted a diagram of the lines up. The only thing that will happen if you drive with them messed up is the 4wd won't work. That's all, not gonna damage anything.
Old Feb 21, 2011 | 08:06 AM
97tn4x4's Avatar
97tn4x4
And as far as what the switch does, when you shift the tcase into 4wd there's a selector in side that rotates. On the end of the switch there's a ball that opens and shuts off the vaccum supply. When the selector rotates it pushes the ball up putting vaccum on the cad causing the collar to slide over and then you've got 4wd. I can't stress enough how awesome the 4x4 posi-loc kit is. Never have worries again.
Old Feb 21, 2011 | 11:09 AM
byronpen's Avatar
byronpen
I know that its alot to ask, can someone send me some picture of the hook up, byronpen@hotmail.com.
Old Feb 21, 2011 | 04:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Are you saying the hoses/lines that go to the switch are F'd up? If so good luck, those four hoses go into a rubber boot that connects to the switch one way only.
