Guess My Heater Core's Leaking
Old Feb 27, 2011 | 08:35 PM
ghost4321's Avatar
ghost4321
If you don't want to change it right now at least carry the hoses and tools necessary to bypass it. You don't want to be driving along pumping all your coolant onto the floor.
Old Feb 27, 2011 | 09:46 PM
beefythedodge's Avatar
beefythedodge
Its not that hard, would def be worth just doing it. If not, then ghost is right. Better be prepared.
Old Mar 6, 2011 | 03:06 PM
DodgeRam10's Avatar
DodgeRam10
Originally Posted by redneck_ram
no problem. one other thing, there are the a/c lines that run through the fire wall. they are supposed to be disconnected, however they dont have to be. i replaced my heater core without disconnecting mine. good luck with it!
how did you do it without disconnecting the ac hoses, i have it all apart and im trying to pull the box but its getting caught up and the only thing still connected id the ac lines, and i cant get it pullled out far enough to get anything out.
Old Mar 6, 2011 | 06:50 PM
DodgeRam10's Avatar
DodgeRam10
anybody have any tips on getting it off without disconnecting the ac lines? thats all thats holding it from pulling out, and i can almost get the core out by lifting up but not quit. i tried to take all the screws off of the bottom of the box bt theres no way i can put them all back on without taking the whole box off. sorry if this makes no sense. it looks like theres a core or somethig that the ac lines go into right next to the heater core..both in the duct box.
Old Mar 6, 2011 | 08:00 PM
redneck_ram's Avatar
redneck_ram
you have to kinda tug on the a/c lines a bit. after i got it out more i took my air cutoff and cut the heater core lines off near the heater core and it will come right out. then just slip the new one into place.
Old Mar 6, 2011 | 08:27 PM
DodgeRam10's Avatar
DodgeRam10
ok i thought about cutting them but wasnt sure if i could get the new one in if i had to cut the old onyes out.ill have to try that tomorrow cuz its gettin dark now, man i hope i can put all these screws back where they go.!.
Old Mar 6, 2011 | 08:31 PM
DodgeRam10's Avatar
DodgeRam10
oh one more thing, about the foam gasket or whatever materiak it is that is on either side of the heater core, and in the fire wall where the hoses come in, should i replace those? mine got kinda jacked up with me tuggin on it. i dont see the gaskets to buy at autozone or kragen.
Old Mar 6, 2011 | 08:38 PM
redneck_ram
just re-use them, i did.
Old Mar 6, 2011 | 08:48 PM
DodgeRam10's Avatar
DodgeRam10
alright just didnt know, thank you for all the help and i might ask ya another question when i put it back together...some brackets fell when i dropped the steering and im not sure where they came from but ill try to figure it out before i bug anyone..thanks
Old Mar 7, 2011 | 03:02 AM
working4ev's Avatar
working4ev
Hi the hector core can be changed WITH OUT removing the heater box and with out discharging the A/C system.
Trust me I did it took about 2 hours.
https://dodgeforum.com/forum/2nd-gen...tructions.html
Thank Baddnet for the info I just put pictures to it.
