9.25 rear- lubrication calls for API GL 5, SAE 75W-90. Pull the plug the fluid should just trickle out. The fluid should appear "clean" just like thick motor oil, not milky or dark. The fluid should also not smell burnt.
There are two plugs square some ore resessed some stick out. Remove the one that is on the upper side of the pumpkin houseing...If you remove the bottom one it will pour out.. You should feel the 90wt right at the lip of the hole. If you go to Jiffy Lube to do your oild chaange they check this
