Old Aug 4, 2015, 07:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
Oxygen Sensor Questions?
Old Jul 29, 2012 | 10:58 AM
  #41
It's Me Patt's Avatar
It's Me Patt
Originally Posted by gdstock
No problem with the cable being longer.....but it was probably the rear one which is longer from the factory. As long as it connects and read, it will be good. I use two rear O2s on my Yota because it is easier to connect with the extra slack. Just make sure the wire does not get against the exhaust and melt insulation.
I zip tied the oppsite side down where the short drive shaft is..I did check the sensor side but I'll double it again check today..Thanks for the info!!
Old Jul 29, 2012 | 11:55 AM
  #42
It's Me Patt
Originally Posted by jasonw
No, that should not cause a problem. What brand of sensor(s) did you buy?
Thanks! I'm using denso..got ripped off by advance auto ($67-$13.40 discount), (rock, $36.23 that's with shipping)..guess I'll start using rock auto..
