A/C problem
Whatever! Other then the fact it's freezing cold out and the AC will cycle fast when on a lower setting when it's already cold out! THE OP WAS ORIGINALLY , talking about AC cycling when heat on, NOT AC!!!!!!!!!!!!!!! If the the 134A was low, it would cycle for sure when turned to Max AC. Think what you want how the system works. Fords And Chevy's operate the same way in years of comparison.
I tried it with the A/C also on the highest fan setting, but blowing on the floor and top vents, and it still did it. This is when I'm thinking it shouldn't. It only worked and didn't cycle when the top switch was on Max A/C and the fan switch was on the highest setting.
