LP gas
Old Feb 23, 2011 | 10:57 AM
sungod's Avatar
sungod
The only real advantage to using LP is off road where you can run near verticle and still get fuel. Of course your oil pickup may not like it. LP is a by product of oil refining. The prices track that of gasoline. There is less stored energy in LP so you will not get as many miles per gallon with it. I wouldn't mess with it.
Old Feb 23, 2011 | 11:01 AM
Silver_Dodge's Avatar
Silver_Dodge
It also produces about 10-15% less power then gasoline does.
Old Feb 23, 2011 | 11:10 AM
crazzywolfie's Avatar
crazzywolfie
but it also creates less emissions and burns clean which can cause the engine to last longer.
Old Feb 23, 2011 | 11:56 AM
pcfixerpro's Avatar
pcfixerpro
Where did you find this?
Old Feb 23, 2011 | 12:28 PM
Flue's Avatar
Flue
Internal Engine Comparison
Old Feb 23, 2011 | 12:34 PM
Silver_Dodge
Have just read it before.
Old Feb 23, 2011 | 03:20 PM
93grandzj's Avatar
93grandzj
i would do the swap if I could amass the pieces for less then the 3000 for a kit plus they want installed and a switch between the two. propane is way cleaner and could run it just tooling around town. when its time to play, flip the switch to gas and have the power back in action.
Old Feb 23, 2011 | 03:25 PM
biff10's Avatar
biff10
Here's what I have and I will get the pics up. I found where in the inlet is for the gas lin that isnt there from the rear tank.
The first pic is where the gas line comes to.
2nd is the intake. I have to find someone to hook it up and test it if I am going to use it.
Old Feb 23, 2011 | 10:03 PM
lazyboy's Avatar
lazyboy
if it is all in place and in working order you have many advantages. runs cleaner, cooler and the best of both worlds being duel. check on line for much info on this. the setup itself is the only stopper for me. you have a jule.
keep us updated if you go forward or let me know if you would like to sell the lp setup.
Old Feb 24, 2011 | 08:38 AM
biff10's Avatar
biff10
I am hoping to get some manuals on the set-up so I know how it should run.
