swapping out my scrapomatic trans for a manual trans
Old Feb 23, 2011 | 12:49 PM
stogie300's Avatar
stogie300
Default swapping out my scrapomatic trans for a manual trans
i got a 97 dodge ram 1500 4x4 with an automatic trans an its gone bad an i just got a doner 97 dodge ram 1500 4x4 with a manual trans what will i need to do to do the swap
Old Feb 23, 2011 | 12:52 PM
TheBigRedOne's Avatar
TheBigRedOne
Haha, wow. You will need every single part that is associated with the transmission, pedals, linkages, etc. Rebuild your transmission, and let it go.
If you have the whole donor truck, you should have everything you need. Might not be a bad plan to replace clutch/pressure plate/throw-out bearing though.
Old Feb 23, 2011 | 01:01 PM
stogie300's Avatar
stogie300
well im goin to put a new flywheel an all that in new but im not sure what i need to do electricly like do i need to do any kind of wiring or what?
Old Feb 23, 2011 | 01:11 PM
dodgeboy7's Avatar
dodgeboy7
He has everything he needs already. It not that hard, I just finished mine 2 weeks ago. Not hard at all with a donor truck and theres another guy on here that did it without a donor truck and spent less than a stock rebuild auto.
When I did mine I had a ram 2500 with the nv4500 same thing just bigger transmission. But here is a list of thing I swapped with mine or bought.
-new flywheel
-new clutch
-Crank sensor
-Engine and trans wiring hardness
-hydro for clutch
-Plastic peace around steering column
-Had to buy a new pcm with my vin number in it for a manual
-Pedals
Think that all
But after buying mine and parting the rest out I made all mine money back from the truck and more. I ended up only spending 144.12 to do the whole thing and that rebuilding the 241LD transfer case too. If you have any questions feel free to email me I be happy to answer.
Last edited by jasonw; Feb 23, 2011 at 02:04 PM. Reason: Removed insulting comment.
