diesel swap
Old Feb 24, 2011 | 01:15 PM
bert67's Avatar
bert67
Default diesel swap
i was woundering if the 4bt swap into a 1500 is worth it and if u can still pull a trailer and everything like u can with the magnum and how reliable the 4bt is
Old Feb 24, 2011 | 01:18 PM
ColoradoRamLover's Avatar
ColoradoRamLover
youd have to replace axels and what not too... your better off buying cummins etc
From what I have read, the 4bt, when properly built and maintained, is basically indestructible. Some folks have been running 60 pounds plus of boost, cranking over 400 horsepower... etc. And still get fuel economy in the 20's.........
If you have the money to play, looks like a reasonable plan to me.
Old Feb 24, 2011 | 01:40 PM
Rave71's Avatar
Rave71
Haha I've learned anything is possible if you have $! There are some videos on youtube of a guy with a cummins in his Dakota, it's pretty B.A.
Good luck with your swap
Old Feb 24, 2011 | 01:44 PM
bert67's Avatar
bert67
i was just woundering if it would be worth the money and i dind tknow how reliable the 4bt is because if i do it im not going to do it all at once im going to slow start buying everything and try to find a used 4bt so i can get it cheaper and i want a diesel but i cant bring myself to sell my truck ive had to many good times in it and it has also never let me down even with the 318 and 46re in it i hooked up to a titian and after that the titian had twisted axle and blew his rear end and that truck has only 20,000 miles mine had 193,000 at the time but back to the diesel i just want something i can still pull a trailer with and still have the power to play around in the mud ive heard u can directly bolt a 6bt into the 1500s without any problems but i dont have the money for a 6bt but i also am having trouble locating a 4bt for a descent price
Old Feb 24, 2011 | 01:49 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I bet someone could take a truck like that off some sweet jumps.
Old Feb 24, 2011 | 01:53 PM
That looks like it would be more work than just jogging.... slower too.....
Old Feb 24, 2011 | 01:59 PM
Rave71's Avatar
Rave71
lol
Old Feb 24, 2011 | 04:43 PM
Gerehead8's Avatar
Gerehead8
You will pay the same for a 4bt and a 6bt as the 6bt is much more common. You can bolt a 6bt into a 1/2 ton but you will crush the front suspension, there is a reason the things only come in 3/4 ton+ trucks. 4bt has same durability reputation as the 6bt, Cummins only builds industrial grade engines. A mildly turned up 4bt will have as much power as the engine in your truck and get 20mpg+.
Do a search on 4btswaps.com.
Old Feb 24, 2011 | 04:50 PM
dodgeram07's Avatar
dodgeram07
http://www.4btswaps.com/forum/index.php im not on this forum but i do drop in and look there is alot of great info
i have thought about doing it my selft at one time, i think your better off finding a truck(like a chip truck) buy the whole thing use the parts and then part and scrap the rest
or
i was also looking into just get nv4500 2wd trans, and 4bt motor, and going to the junkyard and pull the clutch pedals and links out
