Door Buzzers
Old Feb 24, 2011 | 07:07 PM
kuziwr's Avatar
kuziwr
Default Door Buzzers
I had a 2000 ram a few years ago and now i have a 97. My 2000 had a nice soft pinging when the door was open, and the 97 has a stupid annoying loud buzz. Has anyone changed there door buzzers, or any suggestions?
Old Feb 24, 2011 | 07:10 PM
loneriderty's Avatar
loneriderty
it under the dash take it out. but remember when your headlight are on it doesnt tell you. i did that on my 96. i couldn't stand it when i was listening to the radio.
Old Feb 24, 2011 | 07:20 PM
94ram4x4911's Avatar
94ram4x4911
where abouts is the buzzer at so i can rip it outta my truck?
Old Feb 24, 2011 | 07:22 PM
EndIsNear's Avatar
EndIsNear
No, dont take it out. On the steering column, unsrew and remove the top and bottom plastic covers. Underneath the key cylinder is a two wire connection. Unplug it. Door buzzer stops, everything else functions normally. You could even wire it like I did to the key ring light for those of us that dont have the light from the factory
Old Feb 24, 2011 | 07:25 PM
kuziwr's Avatar
kuziwr
Is it possible though to put the newer one into my 97?
Old Feb 24, 2011 | 07:28 PM
loneriderty
umm i don't think they're the same going to junkyard and see if they can get you one to try .
under the dash right around your brake pedal it a little black box. but like i said you take it out and leave light on it doesnt work or when mil come on
Old Feb 24, 2011 | 08:33 PM
dhvaughan's Avatar
dhvaughan
i don't think so. on my 01 the dinger is in the CTM box, under the dash and sort of behind the cigarette lighter. its controls all things timing related. i don't know where the 97 buzzer is, but the likelyhood of it being interchangable with the 01 is slim to none.
as said, remove the column covers and unplug the switch connector.
Old Feb 24, 2011 | 08:57 PM
offroadjosh's Avatar
offroadjosh
I thought i heard somewhere the dinger from a jeep would work...
Old May 14, 2012 | 01:20 AM
pattaugher1995's Avatar
pattaugher1995
if i remove it, i just loose the buzzer if i leave my lights on?
