trans problem
Old Feb 24, 2011 | 08:19 PM
methpmp's Avatar
methpmp
Default trans problem
Its a 99 2wd with 5.9 1500. It wants to take off in 3rd sometimes. I can get it to mess up if leave from a stop light and get up to about 30 then slow down to about 15 - 20 and go back up to the speed limit.. it will say in third then about 40 and it just makes the truck struggle it seems. I can pull it into 2nd and it goes and there is about a hundred rpm difference .. what could be causing this.. other then when this occurance happens it shifts perfectly fine .. it has 145k miles
Old Feb 25, 2011 | 01:40 PM
matty675's Avatar
matty675
your not exactly clear... but replace the governor pressure sensor and solenoid
