2000 Dodge a/c air flow problem
Old Feb 26, 2011 | 04:38 PM
hbarker's Avatar
hbarker
Default 2000 Dodge a/c air flow problem
Ok ,, Not sure if this is goin to make since but here goes..
My 2000 dodge 5.9 gasser . In the summer months when trying to run the a/c it blows and cools fine. HOWever.. when you start to go up a hill the dash air stops blowing untill you crest the hill and or take your foot out of the pedal..
Im gonna burn up in the summer if I cant get this figured out.. ;;
I might add that some times ( hen climbing) I notice the air flow shift more to the defrost, hmm
Old Feb 26, 2011 | 07:28 PM
ghost4321's Avatar
ghost4321
Common problem, do a search for "wild vents"
Old Feb 26, 2011 | 09:12 PM
matty675's Avatar
matty675
+1, its a check valve
Old Feb 27, 2011 | 12:58 PM
hbarker's Avatar
hbarker
OK I pulled the one closest to the firewall ,, can blow one way ,, but seals tight the oposite direction. The other one I cant seem to get it off, dang.. So let that be theone?
Old Feb 27, 2011 | 12:59 PM
Check for leaks downstream of the check valves as well. There is one line that runs off to a reservoir under the cowl. The plastic lines get brittle, and break with age.
