After Market V10 Tach
Old Mar 1, 2011 | 02:41 PM
Dormaar21's Avatar
Dormaar21
Default After Market V10 Tach
Has anyone placed an aftermarket Tachometer on a V10 Engine?
There is no distributer to get the signal from and the control modules are batch fired (sprack plugs fire once every crank rotation) so a pulse indicator from a plug wire will show the engine spinning twice as fast. The engine is being installed into a 1966 Fargo so the stock cluster from the '94 Ram is of no use.
Thanks,
Old Mar 1, 2011 | 03:14 PM
Silver_Dodge's Avatar
Silver_Dodge
I can't help you on the tach, but I hope you come back when this project is done with some pics. I'd love to see a Fargo with a V10 in it.
Old Mar 1, 2011 | 03:17 PM
Silver_Dodge
On second thought, have you tried searching for tachs using a Dodge Viper as the vehicle application instead of a Ram? I realize the V10's are not the same between the two, but the tachs may be interchangable if the ignitions systems are similar.
Old Mar 1, 2011 | 08:40 PM
VEETEN's Avatar
VEETEN
Can't you just hook it up to the tach signal the PCM is already sending to the stock tach?
Old Mar 1, 2011 | 09:21 PM
VEETEN's Avatar
VEETEN
Just poked around real quick and found this
http://www.speedhut.com/custom_gauge...number-751.htm
A bit pricey but it was the first one I clicked on and it just happened to be for a distributerless system.... Lucky click I guess
Old Mar 1, 2011 | 09:56 PM
Dormaar21's Avatar
Dormaar21
I have found a few different tach options out there but none of them match what I'm looking for (I've designed a gauge panel to replace the stock so all the gauges need to be styles, and matching... I can be picky at times). And the ones I do like and would like to put into the truck aren't availible for the V10 PCM. After starting the thread I found this! http://www.dakotadigital.com/index.c...rod/prd127.htm
With this I should be able to install any electric tach I want, just have to find the right signal source and see if it is compatible. I have an engine service manual on order so should have a wiring diagram soon.
