Aftermarket Tachometer
I have a 5-speed truck and wish to install an aftermarket tach at some point in the near future. The ones at Napa are not very clear on intallation instructions.
Any advice? Installing it in the cab seems pretty straightforward except for plugging it in for lighting power.
I bought mine at advance auto. It was very straight forward but be careful that you compress the splices when you tap into the negative wire coming off the ignition coil. I was going to buy a single pod a-piller mount to put mine in but it came with small bracket and I just screwed it into the a-piller right about the dash, fed the wires right down by the fuse panel on the inside of the dash corner, and down just below the steering column and drilled my 3/8" hole in the firewall. I routed the wires out to + and - on battery and green over to splice into the cable at the ignition coil. then I just plugged the white wire up to running lamps fuse so the back light only comes on when lights are one. It was a pc of cake. Get you some cable ties and run your wires wherever but not near a large source of heat.
Install of a tach is very easy. You just need a ground wire, a switched ignition power source, a light source that powers on with the dash lights, and then the tach signal comes from the wire off the coil (I think it was black with a brown tracer on my '99). For a tach signal, a solder connection is better then a splice. I also once read that for a tach, you should make your connection as close to the coil as possible. I can't recall why now, I think it has to do with signal strength or something.
I agree with 97Rampowerhouse. There are some really obnoxious aftermarket gauges out there. I went with this VDO tachometer because it almost perfectly matches the dash gauges, right down to the way the needle is designed.
Trending Topics
