keeps revving
Went through the carwash and mid way through the wash the idle dropped the truck ran rough. I could barely get out of the wash bay almost like I had water in the distributor. I gave her **** it hesitated and then went like a bat outa hell all is good now except when you tap the gas it holds the revs to about 1000rpm for like 3 seconds then returns to normal. Almost as if the gas pedal gets stuck for a second or two. Any help on this would be appreciated. Could it be a case of something getting wet that shouldn't of?
I have just recently gutted my cat as well
probably water in the tps. i once had one that surged when it got wet. your's will probably fix itself when it dries out. you might be able to put a little di-electric grease around the wire connector to keep it fixed. when mine did that i got pissed off at it and replaced it.
