Can i swap a 96 dodge ram dash with a 1999
Old Mar 6, 2011 | 07:18 PM
lmoore2422's Avatar
lmoore2422
Default Can i swap a 96 dodge ram dash with a 1999
I have a really bad destroyed dash in my 1996 dodge ram.
my uncle just totalled his 1999 dodge ram.
is it possible i could use his dash to replace mine?
i know one is digital and one is not.
thanks
Old Mar 7, 2011 | 02:44 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
Its not really possible without doing a lot of custom wiring, maybe even some other interior changes to make it fit properly.
I will move this to the 2nd gen Ram section (1994-2001 Rams) for you.
Old Mar 7, 2011 | 10:13 AM
A lot changed between years there. You might be able to do it, if you use the wiring, and instrument cluster from the 96.... don't know....
Old Mar 7, 2011 | 02:43 PM
lmoore2422's Avatar
lmoore2422
The two do have same amount of miles so no od fraud here. Just wandering if I used the harness to would plug up under the hood.
Old Mar 7, 2011 | 02:57 PM
Probably not, as the instrument clusters are quite different.
Old Mar 7, 2011 | 04:20 PM
brewman's Avatar
brewman
Doesn't the 99 have a passenger air bag as well? I know the 96 didn't
Old Mar 7, 2011 | 04:23 PM
Yes, it does indeed. Good Point. Wouldn't have to be hooked up I suppose...
