V10 Deck Height and Compression Height
Old Mar 10, 2011 | 12:37 AM
Dormaar21's Avatar
Dormaar21
Default V10 Deck Height and Compression Height
I'm rebuilding a Magnum V10 but do not know what the stock Deck Height is for the block, the Deck Distance (depth of piston top inside of bore at TDC), or the pistons Compression Height. Also if someone can confirm the Connecting Rod length is 6.221" or 6.123" (which is the same as 5.2L and 5.9L)? With this information I can find something else that will work or custom make pistons.
I'm having a few issues finding the right information, there are a few assumtions out there but nothing concrete yet.
Thanks,
Old Mar 10, 2011 | 12:59 AM
matty675's Avatar
matty675
rod length is 6.123.
i wish you luck, your venturing into unchartered territory
Old Mar 12, 2011 | 01:10 PM
Dormaar21's Avatar
Dormaar21
Man, in two days this post is 6 pages into the forum, this is a refresher post.
Old Mar 12, 2011 | 04:07 PM
Best info I can find says:
stock pistons are .067" in the hole.
9.735" deck height
Old Mar 12, 2011 | 08:51 PM
jrp267's Avatar
jrp267
Please though do post any info you find so that others may find it easier. I find it tough to get any v 10 info.
