Truck is all done but. . .
Old Mar 10, 2011 | 10:45 PM
  #21
bdj5773's Avatar
bdj5773
Originally Posted by 97Rampowerhouse
I installee a 180 stat when I did my plenum fix. I never see the temp gauge touch 200, it runs at 170 180 I have efans also. But as far as your truck I would just let it idle and rev it up a little. use a glove and grab the thermostat hose and see if its still stiff if so then its the t stat
Before I did my plenum fix with stock t stat I was running about 220 230. For some odd reason these trucks like to run hot
I had a 180 stat before and it ran 180. Hose doesn't fill stiff. I can squeeze it and coolant will push up out of the top of the radiator (cap is off). I'm letting it cool down and going to try it again.
Old Mar 10, 2011 | 10:59 PM
  #22
bdj5773's Avatar
bdj5773
No luck. Still stuck at around 230. I don't know what else to do exact to get a new thermostat and see if that's it. The coolant level is high as it can go; can't add any more to it. I will try tomorrow.
Old Mar 10, 2011 | 11:34 PM
  #23
Mad_Scientist's Avatar
Mad_Scientist
Fan clutch?
Old Mar 11, 2011 | 09:37 AM
  #24
bdj5773's Avatar
bdj5773
Originally Posted by Mad_Scientist
Fan clutch?
No, fan turns great. I still have my old thermostat which worked just fine. I'm going to put that one back in and see what happens.
Old Mar 11, 2011 | 09:46 AM
  #25
drewactual's Avatar
drewactual
yeah dude, it sounds like your 'stat... if the rad cap is tight, and the engine is at operating temp, that upper hose should be full and very difficult to squeeze.. It sounds like there is no flow.
fwiw: I've made a habit of testing every new stat before I put 'em in.. boil some water on the stove and drop it in.. get a flashlight and a fork.. when small bubbles start rising in little columns, hook the stat with the fork and pull it off the bottom of the pot and shine a flashlight on it, hopefully watching it open..
here is the part most folks leave off: when it is at a full boil, the stat should be opened at it's max.. pull it completely out of the water, and watch it close.. then put it back in- open- out, close.. sometimes they bind on themselves.. this way you will see if that is happening to yours..
if it checks out, I highly rec drilling two small holes in the gate.. on opposite sides, and no larger than 1/32".. this helps air purge quicker, as there is flow through the stat even when it is closed (though not enough to cool the engine excessively though)..
another thing: on the neck of the stat housing, there is a little tab that rests under the accessory bracket that makes this job a PITA.. you can grind that baby off, and turn any future stat swaps into a ten minute job..
good luck!!!
Old Mar 11, 2011 | 10:02 AM
  #26
bdj5773's Avatar
bdj5773
good luck!!!
Thanks for those tips. I'm about to go out and put the old stat in and see what that does. I know it works. Hopefully that will take care of the problem. I will update either way. I am so ready to get this truck going; been more than a week now since driving it.
Old Mar 11, 2011 | 11:00 AM
  #27
bcertain's Avatar
bcertain
If you change the stat and still is running hot, then check you fan clutch, if it is spinning too freely it may not be spinning fast enough with the motor. Have you replaced the waterpump? Have you flushed your radiator? If it has clogged passages it will not cool properly.
Good luck and let us know what you find.
Old Mar 11, 2011 | 12:32 PM
  #28
bdj5773's Avatar
bdj5773
No luck; doing the same thing. Temp. right at 230. I believe I will just take it to the shop. Tired of fooling with it. The question is, is it safe enough to drive a few miles running at that temp.
Old Mar 11, 2011 | 12:37 PM
  #29
drewactual's Avatar
drewactual
take the stat out and run it..
Old Mar 11, 2011 | 12:44 PM
  #30
bdj5773's Avatar
bdj5773
Both stats can't be bad. I'm going to test it. Someone suggested that the fan clutch may not be turning sufficiently but it was working just fine before I took it out and it is working just fine now. It is too much of a pain getting to get to the stat. I think I will let the shop deal with it. So, is it okay to drive it a few miles (about 10) running at around 230?
